ok guys well i have decided to go with the lst rather than the muggy
i have orderd the impakt rc motor mount and mikes 2 speed adapter
i will probably fab my own battery tray i will try the motor mount out but will probably have t fab some thing up to get it to work right but when it all turns up i will let you no how it went and get some pics up for ya to check out
cheers for ya advice
now i just have to weight
hi guys had a look at my truck now thinking that the engine mount fron impakt wont fit has anyone tried the motor mount that dudes made on a lst yet and the single speed gear hub
whats the quality like
ease of use
ease of mounting
cheers
the motor mount isn't out yet, The Dude uses the Captain as a tester, that is why he is expecting one. Otherwise I have one of his single speed hubs and they are great. Definitely recommend it.
ok guys has any one put the emaxx gearbox in the lst if so do you need to change the gearing i have a emaxx chassis plate and gearbox i could bolt up to the lst chassis
but what would the best gearing be to use i do have the strobe slipper and the ofna spur that i use on my bl revo would this be any good and what size pinion would you recomend
I did this, it works with some mods to the LST chassis, the gearing is ok. The maxx box in stock form won't hold up well if you're running any serious power though.
