captanabolic
captanabolic's Avatar
07.28.2008, 05:22 PM
i received it today will test fit it tonight and run it tomorrrow. Let you guys know what is up. how it performs.
http://captanabolic.onestop.net/drift_manga.gif
FAST ENOUGH TO DO SOMETHING STUPID
REALLY STUPID
THE CAPT IS SOOO SEXY!!!
HOLY HOLE IN THE DONUT BATMAN!!!
jayjay283
jayjay283's Avatar
07.28.2008, 05:29 PM
hot diggity, were rolling now. fingers x'ed GL
lind5
07.30.2008, 04:07 PM
ok guys has any one put the emaxx gearbox in the lst if so do you need to change the gearing i have a emaxx chassis plate and gearbox i could bolt up to the lst chassis
but what would the best gearing be to use i do have the strobe slipper and the ofna spur that i use on my bl revo would this be any good and what size pinion would you recomend
You could...
ilpufxit
ilpufxit's Avatar
You could... - 07.30.2008, 04:29 PM
I did this, it works with some mods to the LST chassis, the gearing is ok. The maxx box in stock form won't hold up well if you're running any serious power though.
lind5
07.31.2008, 06:02 AM
ok chassis mods not a problem emaxx box alreadt upgraded but did you use std emaxx spur or somthing diffrent
cheers mate
Different!
ilpufxit
ilpufxit's Avatar
Different! - 07.31.2008, 12:11 PM
I was using one of Holmes Hobbies early custom jobs, It's a large, low kv outrunner directly running the input shaft. It's a neat set up for speed runs but it's not really very good for the application, too much mass to spin from start-up and it's very sensitive to driveline shock. If I did it again, I would use a slipper and an inrunner motor. However, with what I learned between the e-maxx and the LST, I ended up building a BL Muggy which is way better than either one imho. The Muggy is simply much better handling, mostly due to a low cg but I do wish that Mike would make with the Slipperential!!
cheers mate
