Matthew_Armeni
Matthew_Armeni's Avatar
07.26.2008, 12:34 PM
I run a 1300kv 60mm Medusa in my Losi 8T on 6s through a MM. I run the Tekno conversion with clutch and mechanical brakes. The motor is plenty to pull the truggy around, especially if you are racing it.
  Send a message via AIM to Matthew_Armeni
83gt
07.26.2008, 01:18 PM
That's good to hear. I've been advised several times against the 60mm medusa for a 1/8th truggy. You have no problems with heat ? It's really amazing what those little MM controllers will do. They hang with some of the "best" ESC's out there. I smoked a couple quark 125's and an MGM160 and the MM just kept right on.
