Desmo
07.25.2008, 10:04 PM
Just bend the tabs to make them tighter and make sure to clean the gold side. I have maybe 30 sets of deans on chargers, batteries, vehicles, adapters, etc. Most are knocks offs. The only problems I've ever had was them getting loose. if you have some small needle nose pilers grab the tab and bend it up and curl it a little at the same time.
Jeremy1976
07.26.2008, 12:10 AM
Will do that. Thanks for the advice!
Desmo
07.26.2008, 02:37 AM
I could get a picture, if you would like
maxair45
maxair45's Avatar
07.26.2008, 02:27 PM
I will do that also. It tends to happen to me once I am a little farther into the run. Mabey heat has something to do with it.
JeffEmbracedDC
JeffEmbracedDC's Avatar
07.26.2008, 02:42 PM
#1 Do you have a lot of heavy wire flopping around that can pull on the plugs due to momentum on a hard hit? If so, affix the wires so they can not move so much. Maybe strap the adapter into the car so it's not bouncing around on the air relying on the deans to hold it in place.
If it's all secure and the issue IS the plugs - Bending them can cause for a bad connection. Less surface contact. The best bet would be to replace them with new plugs if in fact the plugs are the problem.
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
