07.27.2008, 12:47 AM
If you are running an external BEC try disconnecting that and running a receiver pack to eliminate the external BEC as the problem. The other thing that could be possible I suppose is the steering servo going bad and creating some sort of interference int he signal of the whole system, but I think the BEC is the more likely culprit.
I had a similar issue with a bad steering servo. As I pulled the throttle the servo would twitch a lot and stay off center. It did not casue any issues with the control of the esc though.
Try a rec pack, and make sure it is fully charged, a pack with low voltage will cause all kinds of problems...
hailmick
07.27.2008, 02:41 AM
try switching your steer servo out like the boys above have said
my buggy has a twitching steering servo but its a nitro its even worse when steering
Trick440
07.27.2008, 01:21 PM
I think we maybe on track. I tried the stock reciever and same problem. I unhooked the steering servo and problem went away. But there is no steering servo hooked up. Im going to hook the stock steering servo up and see what happens.
