ffactory666
07.27.2008, 10:51 PM
Will do cemetery gates once i get a esc to run .If you already have a MMM that is working the 1300kv Medusa sounds perfect for 6S , try it out .
You will probably have it running before i do.
Joe i'm waiting to see if i can fit the CR mount so i can take the bracing away .If it won't fit i will upgrade to the alloy F/R chassis braces .
