You could...
ilpufxit
ilpufxit's Avatar
You could... - 07.30.2008, 04:29 PM
I did this, it works with some mods to the LST chassis, the gearing is ok. The maxx box in stock form won't hold up well if you're running any serious power though.
Originally Posted by lind5 View Post
ok guys has any one put the emaxx gearbox in the lst if so do you need to change the gearing i have a emaxx chassis plate and gearbox i could bolt up to the lst chassis
but what would the best gearing be to use i do have the strobe slipper and the ofna spur that i use on my bl revo would this be any good and what size pinion would you recomend
