johnrobholmes
johnrobholmes's Avatar
08.02.2008, 10:21 AM
Yep, the timing is variable on Castle's ESCs. You set the range it stays in, and it automatically adjusts timing based on load and RPM of the motor.
---JRH---
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.02.2008, 07:42 PM
Ahh, I see....and knowing is half the battle!
mamba monster combos
lind5
Talking mamba monster combos - 08.03.2008, 07:12 AM
hi i was wondering about the monster 2200 combo i have seen it on back order with certain shops saying delivery will start the week comencing 25 august but i cant find anything about the combo date on castle web sight
can you tell me if this would be correct or is this shop just teasing me
lutach
lutach's Avatar
08.03.2008, 09:49 AM
Please look here: http://www.rc-monster.com/forum/showthread.php?t=13919.
lutach
lutach's Avatar
08.03.2008, 05:52 PM
Patrick,
Just came back from running the Recoil. I changed the timing from normal to high and it still heats up pretty good. I'm going to try the smallest pinion I can fit in the car and see if temps go down. Motor wasn't as hot as it was with normal timing though.
lutach
lutach's Avatar
08.07.2008, 11:37 PM
Here is a data I got from running the Recoil at the track.
The MM still heats up even though max AMP spikes are in the high 50's. I even installed a 16T pinion in place of the 19T that was in the car before with the 60A controller. Patrick, what is the max RPM the MM can go with a 6 pole motor?
tc3_racer_001
tc3_racer_001's Avatar
08.08.2008, 04:37 AM
wow. i managed to take out 150A spikes with the Mamba max and it wasnt even warm!! lets hope you can get this sorted :)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
