Extreme budget escs
Metallover
RC-Monster Spudgunner
Metallover's Avatar
Extreme budget escs - 08.05.2008, 05:19 PM
They're here! If you want a REALLY cheap esc, look on hobby city. I was going to get one of these, but settled on the mm. I emailed them about it and look what happened! Suppo esc's carried by hobby city! Here are the prices after you sign in:
60a - 15.99
70a - 18.85
100a - 27.95
Here are the specs of the 100a:
Spec.
Weight: 85g
Cells: 9-21Ni MH ~ 2-7S Li Po
Constant Current: 100A
Max Current: 120A
No BEC
Timing: 1/7/15/30 programmable
PWM: 8/16K
Features.
Constant current 100A Max 120A <10S
Li-Poly 9-21 cells Ni-MH 2-7 cells
Dynamic Braking
BEC: opto
Auto shut down when lose signal
Slow down at 3.0V per cell Lipo, Cut-off at 2.9V per cell Lipo 0.8V NiMh
User Programming options.
Battery setting
Throttle Range
Brake setting 4 options:
Direction and Cutoff Type
Timing Mode Setting: 1 / 7 / 15 / 30
PWM setting: 8K/16K
Who is getting one? I almost wish I didn't get my mm and got this instead. I don't know if they have a soft start, but I think you can program that out. Now only if they started carrying the 200a one....
Here is a link to the manufacturers website: http://www.suppomodel.com/
I hope I'm not breaking any rules by posting this and I'm not trying to get any mods mad at me.
Takedown
WARNING: May become violent.
Takedown's Avatar
08.05.2008, 06:03 PM
Not bad..
RIP- Tammy (9/14/08)
08.05.2008, 06:12 PM
Is it me, or the wires look a little on the small side...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.05.2008, 06:16 PM
I see dynamic braking in the specs, does that mean car brakes or prop brakes?
08.05.2008, 06:21 PM
Prop brakes... Nobody makes car esc's that cheap!
What's_nitro?
Awe....
08.05.2008, 06:23 PM
That's an assumption.
What's_nitro?
08.05.2008, 07:06 PM
They could be made that cheap if someone would put a couple more hours into the firmware for some good brakes!
Metallover
Metallover's Avatar
08.05.2008, 08:21 PM
Here is links to the escs. You need to take out the *'s.
60a-http://www.hobby***city.com/hobbycity/store/uh_viewItem.asp?idProduct=7339
70a-http://www.hobby***city.com/hobbycity/store/uh_viewItem.asp?idProduct=7340
100a-http://www.hobby***city.com/hobbycity/store/uh_viewItem.asp?idProduct=7341
I have a 40a esc made by the same company. I used it with a Neu 1105/2y (5200kv) and it seemed to work great. I never got around to program out the soft start, so I just used it for speed runs mostly in my Sportwerks Recoil. You can get around the soft start a little by going minimum throttle for about a second then you could really hammer it. It stayed much cooler then my Quark 33a.
Takedown - You should get the 200a for your 1/5th if you go through with it. Most of this companies products are stocked at www.lightflightrc.com. You could e-mail them and I think they could get you the 200a. Their prices are a little higher then hobby city, but good luck trying to get something special ordered at hobby city.
Awhile ago I tried to contact suppo directly from the e-mail address I found on the website and I never got it to work. I don't know about customer support from these guys. hehe Support
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
08.06.2008, 10:58 AM
Hey, even with the dynamic breaking, is there any way you could just put it in a truck with mechanical breaks? Would you have to disable the dynamic breaking via programming card for that to work? I'm kinda considering putting this in a REVO, if I could ever get my hands on one...
Thanx,
Brijar!!!
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
azjc
08.06.2008, 12:55 PM
I don't like the LVC setting...slows down @ 3.0 and stops at 2.9....IMO too low could potentially puff packs...I like to set mine @ 3.2-3.3 vpc
Metallover
Metallover's Avatar
08.06.2008, 01:32 PM
You could also run an external lvc if you want. I think that is what the Apogee LOA is.
lutach
lutach's Avatar
08.06.2008, 01:43 PM
60a - 15.99
70a - 18.85
100a - 27.95
Spec.
Weight: 85g
Max Current: 120A
No BEC
PWM: 8/16K
Features.
Dynamic Braking
BEC: opto
Battery setting
Throttle Range
PWM setting: 8K/16K
Yeah a 200A like this one http://www.rc-monster.com/forum/showthread.php?t=7651 would've been good. Good thing Suppo paid for my MOSFETs.
What's_nitro?
08.06.2008, 02:55 PM
That's some coincidence!
lutach
lutach's Avatar
08.06.2008, 02:58 PM
Suppo will still try to make it. After they sent the payment for my MOSFETs, they sent me an e-mail asking for my help again. Only if the companies I help could give me some more credit instead of products and headaches.
