ffactory666
08.07.2008, 04:08 AM
Received and R1 Pro so soldered a 35v cap to it along with an external bec hooked it all up and
Had the truggy running for 5 mins just to test out the R1 since it will be living in the buggy and i didn't want to push it too much in the truggy .
Ran great on 5s and only got two temp leds lit up , very smooth esc , should work great in the lighter buggy .Waiting on a hotwire so i can set the lvc for 5s .
Tempted to take the X2 to the track for a day of running with the R1 on the weekend ( not having run the X2 on a track is killing me ) but i'm a little scared for the little esc .
I know you guys have had great success with it in the buggies but don't know of anyone with it in a heavy truggy.
I'll just be patient with the X2 and wait for the MMM to arrive , shouldn't be too much longer .
Fast5sRevo88
08.07.2008, 02:46 PM
How did u mount the Tekno motor mount ffactory? I have an x1 i would like to have one of those on it.
ffactory666
08.07.2008, 05:45 PM
You have to make 4 countersunk slots in the chassis for the mount and to allow gear mesh adjustment.
I just measured up drilled two holes ( make sure they are the right size for the screws ) were each slot starts and ends and then completed the slot with a dremel milling bit
Of course then i used a countersink bit . Dont forget though if using this mount you have to brace you centre diff somehow like i did .
ffactory666
08.08.2008, 02:04 AM
Got a little present from Mike today
Needless to say i can now confirm for you guys that the CR buggy mount fits the X2
Just need to take the dremmel and put a notch in it were it sits on the center chassis brace for clearance .
You can see it in the pic .
Also Mikes mount is about 1mm taller than the stock diff mount so you just have to shim the top of the stock mount so the top diff plate sits square . Bearing carrier is spot on .
Now i have gotten rid of the centre diff braces i had to use on the Tekno mount, a lot cleaner looking
Also received my custom one piece battery trays , perfect .
They clear the diff nicely , sit on the mudguard spot on and best of all i can now use my Zippy packs along with the enerland cells .
After speaking to Jeff i also got the front wall of the tray machined thicker for those hard lawn dart accidents
ID:	5214   Click image for larger version
ID:	5213   Click image for larger version
joeling
joeling's Avatar
08.10.2008, 11:10 PM
ffactory666,
U are doing good work here. Thanks for the pics & info. Invaluable.
Regards,
Joe Ling
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
ffactory666
08.11.2008, 05:19 AM
Originally Posted by joeling View Post
ffactory666,
Regards,
Joe Ling
No prob Joe , thats what these forums are for
