bdebde
That's All Folks!
bdebde's Avatar
08.12.2008, 01:52 AM
Griffin, what would a good timing setting be for big max on other controllers (MMM)?
rhylsadar
rhylsadar's Avatar
08.12.2008, 04:35 AM
hi
101001
you may choose the second one on 1 too. boat modus has a very smooth brake that may put less stress on your drivetrain.
bye
rhylsadar
ps: put a nice fan on the heat sink and solder some short leads to the 3.5mm plugs. so you do not have to remove them anytime you take off the motor. you may solder 4mm on the other end to connect to the motor. also two additional capacitors are not a bad idea.
______________________
Exercitatio artem paravit
rhylsadar at youtube
mohanjude
Need for speed
mohanjude's Avatar
08.12.2008, 09:16 AM
Thanks for the info. I have basically set the controller on the settings you mentioned and it works well. I believe the DIP switches can be set for Medium / Low for Lehner or hacker motors.
The Boat mode makes the brakes very very weak. In fact the 16lb truck will not stop safely. So I have returned the settings to car.
Mohan
