speedracer1129
08.12.2008, 08:54 PM
We run the TC4 on 4S at over 100 with a MM5700 setup. The car WILL handle it!!
tc3_racer_001
tc3_racer_001's Avatar
08.13.2008, 07:32 PM
thats what i love about tc3's. as long as you can steer it, it can handle it...
ive got a shaft coming which should be here next week, i will post a picture of it when i get it. cost $42us shipped international.
will the 5700 handle 4s reliably, or will it grenade? thanks
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
B15
08.14.2008, 09:50 PM
The stock plastic diff outdrives and stock aluminum driveshaft cant handle much, but those are easy fixes.
Neither, the magnet wont seperate, but itll run too hot for the magnet to hold its strength for long. Its doable for short runs.
speedracer1129
08.15.2008, 11:24 PM
The stock center drive shaft will work with no problem.
Too hot in what sense?? When you set up a car for 100mph speeds, you are not going to have a car that will play for 10 minutes straight! We get about 10-15 passes of about 600 feet with the setup before it hits about 170-180 on the motor and 150-170 on the ESC, We then let it cool down for about 30 minutes before running them again. This setup also consists of no extra cooling added!!
B15
08.16.2008, 01:45 AM
Ive killed 2 stock center driveshafts w/ my 4s tc3. They flex in teh middle then centrifugal force flings them out, shattering receiver cases on the way.
I tried a 5700 on 4s with similar results to what you described. If thats what you call reliable, then sure its reliable. IMO if it cant survive a full battery it isnt reliable. My 4600 can run for a whole battery while geared for over 100 without heat issues. Ive only managed to do that a couple times because crashes at those speeds are pretty spectacular (and expensive). Thats with no fans or extra heatsinks, I guess the airflow is pretty good at those speeds.
tc3_racer_001
08.16.2008, 02:01 AM
those shafts are the only weak bit.. i wonder if you could convert it to pulley drive?
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
lutach
lutach's Avatar
08.16.2008, 02:24 AM
I have the carbon fiber drive shaft in my TC3s and they are great. I can still beat the crap out of the new TC in the market.
