Whoops. I need to touch up on my skimming...
I've never rebuilt any shocks before.. What is a good brand/weight of shock oil for a revo with a rtr weight of 7-9lbs?
7 to 9 lbs is a huge difference. If its 7 lbs (which I seriously doubt), then you should be down in the 20-30WT. Over that, and you will be up into the 50-60wt. Also depends on which spring you run.
