Shark413
Shark413's Avatar
09.05.2008, 01:03 PM
Hey guys,
Truckbasher, it handles much better than the stocker. With 4wd drive, lowered CG, center diff, and firmed up suspension it handles like an 1/8 buggy, except for the tires (traction not as good). I have 17mm adapters, so I could add buggy wheels, but I will stick with the stock ones for a while. The Pushrods are off my Axial Crawler, I replaced the suspension links with bent links so I had a bunch left over, just cut to length, and threaded Revo ballends on. I use the stock Revo washers (little red ones) to adjust the CG/ride height.
JeffembracedDC, yes the motor is probably overkill, it was in my Kyosho ST-RR and the front bearing went out. While I was waiting for it to be repaired I replaced it with the Tekno version. So when the Neu came back I had an extra motor so I figured why not try it in the Slayer.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
