View Poll Results: Status of your MMM v2
Working Normally 57 47.50%
Failed 46 38.33%
Failed violently, potential safety concern 17 14.17%
Voters: 120. You may not vote on this poll
09.09.2008, 02:40 PM
Many are adding some type of foam standoffs placed on the motor and power solder areas to keep the circuits from hitting the case. That and a little dremeling of the case to allow more clearance. The foam solution works well and requires no permanent modification - just 2-3mm of added foam provides the clearance needed.
CC really need to add some sort of pcb suspension, or something. When I pulled the bottom plate off the dead v2 I had to laugh, that little foam thingy stuck to it is next to worthless, all it will do is stop the fan connector scratching the case...
I added some shrink tube to the fan wires on my v1, they were starting to rub thru on the pcb. I also added shrink to the wires as they exit the case, they were looking like they could be damaged too. Pity the BECs die, seems like a decent controller. I do not mind adding the foam cushion and the case clearancing, but running without a bec is a bit much...
CRTIM
09.09.2008, 02:47 PM
a little off topic i suppose but... has the poll stats been adjusted at all as failures happen after posting that it is working normally ??...or are those fairly accurate stats ?? thanks
jhautz
jhautz's Avatar
09.09.2008, 02:49 PM
Nope. I voted working normally and then mine failed later. I'm sure there are others.
to make it...
or break it...
Silent...But Deadly
CRTIM
09.09.2008, 02:53 PM
yeah ,i was afraid of that ....LOL...i have a new MMM v2 and NEU 1515 2.5 still in the box's and not in any hurry anymore to finish my truggy conversion cause i pretty much know it's gonna fail...
....thanks guys for the replies...
