View Poll Results: Status of your MMM v2
Working Normally 57 47.50%
Failed 46 38.33%
Failed violently, potential safety concern 17 14.17%
Voters: 120. You may not vote on this poll
09.09.2008, 02:26 PM
Many are adding some type of foam standoffs placed on the motor and power solder areas to keep the circuits from hitting the case. That and a little dremeling of the case to allow more clearance. The foam solution works well and requires no permanent modification - just 2-3mm of added foam provides the clearance needed.
