09.12.2008, 07:32 PM
Nomadio Sensor here.. had no problems. My radio was reset to factory defaults and MMM was also on factory defaults.
Make sure your RX is bound to your TX.
I'm running a voltage sensor on my battery and a temp sensor on my neu... but that's besides the point.
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
09.14.2008, 11:49 AM
Update:
Messed with the settings, no help. So I created a new default model, and a backup receiver. Connected fine. Further testing with original receiver, using channnel 1 vs channel 2, I was able to get it almost calibrated but not completely. I'll test more.
Intitial testing was with 4s and NEU 1515/1Y/F, I only thought the old Novak HV 4.5 had power. After a 10 minute test, it took 20 minutes to get the grin off of my face. Will be testing with 5s today, 6s if I get brave.
Another question, for Nomadio users with the voltage going to the receiver, I have only used it with 2/3/4s. According to the manual, it will display up to 20v. Has anyone used it with 6s or do I need to worry about frying something with the extra voltage?
Gmaxx G3 with slight mod to allow use of V1 Slipperential, UE 6 spyder diffs, revo shafts, RPM oversize carriers, arms and shock towers. Still has the original front and rear bumper only. MMM with NEU 1515/1Y/F. Nomadio Sensor.
09.14.2008, 12:20 PM
It won't matter wether you run it on 4S 5S or 6S the MMM will olny supply 5.5 volt's to the RX I have seen some people posting on this site saying that with the new MMM V2'S there getting 6 volt's oing to the RX.Most RX'S are ment to be run on 4.8 or 6 volt's so if you ran your MMM on 4S like you said you did and it was putting 14.4 volt's into the RX it would have fried your RX long ago,it would have been up in smoke as soon as the switch on the MMM was thrown.
09.14.2008, 02:29 PM
He's referring to the voltage sensing channel on the Nomadio transceiver, which can be used to monitor the full battery voltage, so that alerts can be set.
If the manual says 20v is the max more probably wouldn't hurt, it probably just wouldn't display it.
09.15.2008, 06:52 PM
I couldn't find the thread, but the head at Nomadio, At least the head of the support forum said anything over 21v will burn the tranciever. So nothing over 5s lipo if you run the telementry
09.15.2008, 07:00 PM
Even the Spektrum receivers can take up to 9.6v..
however, of course just because the RX can handle up to 20v doesn't mean your servos can. Make sure to remove your servos from the system and anything else that may not be able to handle the voltage (personal transponders, etc). I'm sure you know this, but I'm explaining to anyone who may not :)
-Jeff
09.15.2008, 07:20 PM
Thanks for the replys.
I am using the battery input on the RX. I have been using it for a couple of years on 4s with no problems, I prefer to see the voltage of my batteries rather than rely on a low-voltage cutoff. It's easier to see when the power on the batteries are dropping (and time to stop/change batteries).
May be safest to just use it when I am only using 4s. Not racing with it, so stopping to check is no problem. Test it with a meter or just put the batteries one at a time in the rustler and look at the radio for battery voltage. Since I just started running more than 4s, wanted to be careful.
So far MMM and NEU 1515/1Y are lots of fun. Just have to get off the trigger finger, so it won't keep flipping on it's back.
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
