tc3_racer_001
tc3_racer_001's Avatar
09.13.2008, 06:43 PM
problem is, ive had range issues using nimh x8 so i had to use 9x nimh to fix this (i had dead energizers which wouldnt hold their voltage.)
lipo = best option. u could do it if you can cut out that plastic bit and move anything which is housed in it at the moment, u may need 2 flat packs as the pack ive got is like a square (cost $16 from HC)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
brushlessboy16
brushlessboy16's Avatar
09.13.2008, 07:07 PM
i dont know if i want to tear up the controller at the moment
tc3_racer_001
09.14.2008, 01:31 AM
not hard to undo a few screws to see if theres anything important in the way. then u can re-assess the idea.
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
brushlessboy16
09.18.2008, 07:45 AM
i tried... and failed- tried to make as much room as i possibly could, lipo was just tooo wide. so i ended up making an extension for the power connector inside the controller and mounting the lipo on the front portion of the radio's foot.. i know its not the cleanestsetup bbut it works like a charm
My latest dilema is battery placement..
Right now with the battery far back it makes for great wheelies but horrible handling
A few options..
-mount the battery inlin with the chassis, the back resting agains the motor plate.. it moves the weight to the center of the truck and further forward.
-Mount the battery on the front of the truck, in front of the pinion and spur gear on top of the tvp's. weight is further forward by a longshot..
anyone have any input?
