123revo
09.15.2008, 08:32 AM
the lvc was set for 6.4 on the 2s. lets hope this behaviour is a one off...maybe.
Texas-Pete
Texas-Pete's Avatar
09.15.2008, 02:48 PM
I would recommend to:
1. Re-sync your Rx to your Tx
2. Re-sync your tx/rx to your MMM
3. Reset all the MMM settings
4. Change the batts all over/ recharge them all
5. Check all your connections, and double check.
I just had my MMM give the same symptoms, and the culprit was a crossed wire inside one the board.
My anti-drug: E-R-E-V-O
bruce750i
bruce750i's Avatar
09.15.2008, 03:24 PM
How much voltage due you run it on? 7.2v? or 14.4v? What JeffEmbracedDC said basically.
123revo
09.18.2008, 01:18 AM
the li-po is only 7.2v. i just got some evo 25 flighpower packs off ebay real cheap. they are 11.1v, but when i got them they look so small. can i safely run these on my truck? one at a time? parrallel? not at all. they are 2200mAh @ 11.v. i got 2 of them. i am thinking of running them with my lipo sack around them just in case...
guys?
