Since the Slayer is built on the Revo platform, the CoG is a bit higher than ideal. The Revo even rolls unless you make it sit fairly low and/or use offset tires, and the Revo is quite a bit wider. I would lower it and use sway bars if cornering stability is your concern.
Thanks for the input, Brian.
I am not sure of swaybars for the dirt though...I will have to test it.
