Mister-T
09.16.2008, 03:59 PM
Originally Posted by sleebus.jones View Post
6 pole motor too. Hmm.
Hu, it 's a 6 turn motor where did you read 6 pole ?
"We'll never have a ROAR legal motor. They're all copies of Novak's design. We're not willing to copy what we consider to be an inferior motor"
- Joe Ford - my new hero
bruce750i
bruce750i's Avatar
09.16.2008, 04:28 PM
Excuse my French but,
Caractéristiques :
2150 Kv
Bobinage 6 tours
Max 120A
Plus de 2000 Watts maxi
Voltage max recommandé : 25V
Diamètre : 45 mm
Longueur : 76 mm
Poids : 550 grammes
Entre axe trous de fixation : 25 mm standard 540
Format équivalent à un Speed 700 en taille
Axe moteur 5 mm avec méplat
Rotor néodyme diamètre 24 mm
Cage démontable
Roulements énormes gros diamètre ultra résistants
Câblés d'origine avec des prises PK 6 mm mâles
It's all there in plain French? 6 pole??
Mister-T
09.16.2008, 04:41 PM
Caractéristiques :
2150 Kv
Bobinage 6 tours
Max 120A
Diamètre : 45 mm
Longueur : 76 mm
Poids : 550 grammes
Cage démontable
2150 Kv
6 turns winding
Max 120 Amps
Power 2000 watts maximum
adivsed Voltage : 25 volts (it will turn fast with such voltage ...)
Diameter : 45 mm
Lenght : 76 mm
Weight : 550 grammes
Space between mounting holes : 25 mm standard 540 size
Equivalent to Speed 700 i term of size (Speed XXX it a reference to old brushed motor used in RC Aircraft)
5 mm output shaft with plane
Neodymium Rotor with 24 mm diameter
Dismountable housing /casing / stator
Oversized ball bearing for long life
Default wiring with Banana plug (PK) size 6 mm
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
09.16.2008, 08:38 PM
I googled the part number and got this reference:
http://www.rcgroups.com/forums/showp...6&postcount=35
Granted the guy may be off, I didn't really do any backup research on it, whups.
