DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.16.2008, 06:23 PM
Originally Posted by kevin23 View Post
so what gearing are you currently running?
13T/46T - I was first running 14T/46T which was also before I changed the diff fluids and timing and the motor was running 160F - 175F but the ESC and Battery were cool which usually means the motor is undergeared so I went up to a 15T and temps didn't really change (I think it got hotter quicker). So asked around and changed my diff fluids from 3-5-2 to 5-10-3 and timing for D wind motors is mean't to be 0 not 15 or whatever the standard timing is on the Mamba ESC. I also changed the pinion to a 13T and temps went right down. I haven'y tried the 14T or 15T pinion again as even on 13T (42mph ish) it is still fast
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
