Another strange MMM observation in behaviour
123revo
Another strange MMM observation in behaviour - 09.14.2008, 06:51 AM
i have left my revo with the MMM sitting idle for 1 week. i recently rotated the mounting of the motor which required me to disconnect the wires from the esc. today i decided to charge up my Yeah racing 2s lipo for a quick spin. when i connected the battery to the esc i noticed a small spark from the connectors. hoping i hadn't inadvertently fried it i powered it on. it powered up with the first set of 4 tones but not the final set of tones, also the fan kept spinning faster and faster. the red and orange lights flashing on the esc were on but no response to radio input only the reverse mini servo initializing and thats it. i then decided to hook up the castle link to check the settings on the esc. the link hooked up well and then just did an update to ensure all settings were saved. i didnt make any changes but wanted to make sure they were saved anyway.after that, the esc was fine. i thought mine had bought the farm for sure but i hope its not a sign of things to come.
brushlessboy16
brushlessboy16's Avatar
09.14.2008, 06:58 AM
wow, are your liops ok!?
one week at idle can do alot of damage
are you running a BEC or the internal setup
123revo
09.14.2008, 11:45 PM
no you mis-read my post. by idle i meant with it switched off with no use at all.
JeffEmbracedDC
JeffEmbracedDC's Avatar
09.15.2008, 12:12 AM
I'm assuming you don't have the LVC set? If you have your LVC set for a 4s pack and plug in a 2s pack.. well.. it may do what you're describing.
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
123revo
09.15.2008, 08:32 AM
the lvc was set for 6.4 on the 2s. lets hope this behaviour is a one off...maybe.
Texas-Pete
Texas-Pete's Avatar
09.15.2008, 02:48 PM
I would recommend to:
1. Re-sync your Rx to your Tx
2. Re-sync your tx/rx to your MMM
3. Reset all the MMM settings
4. Change the batts all over/ recharge them all
5. Check all your connections, and double check.
I just had my MMM give the same symptoms, and the culprit was a crossed wire inside one the board.
My anti-drug: E-R-E-V-O
bruce750i
bruce750i's Avatar
09.15.2008, 03:24 PM
How much voltage due you run it on? 7.2v? or 14.4v? What JeffEmbracedDC said basically.
123revo
09.18.2008, 01:18 AM
the li-po is only 7.2v. i just got some evo 25 flighpower packs off ebay real cheap. they are 11.1v, but when i got them they look so small. can i safely run these on my truck? one at a time? parrallel? not at all. they are 2200mAh @ 11.v. i got 2 of them. i am thinking of running them with my lipo sack around them just in case...
guys?
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
09.18.2008, 01:37 AM
Dunno if it would cause this, but isn't there a minimum voltage rating on the MMM? Like 3S (11.1) or 10V?
Edit: With those 25C 2200 packs you should run them in parallel for use in a MT. One pack is only good for 55A (610W) continuous. If you only run one pack I think it would get pretty warm. If not, worse.
bruce750i
bruce750i's Avatar
09.18.2008, 04:55 PM
You can run them w/o the lipo sack, just set your cut off voltage at 3.2v a cell. 3s for 11.1v with a cut off of 9.6v or 6s for 22.2v with a cut off of 19.2v. But really they are a little small. I've ran two 1800 3s in parallel (3s2p=11.1v) in my rustler, but they acted a little undersized for my setup. What motor do you have on it? IDK either about the minimum voltage.
myndseye
myndseye's Avatar
09.18.2008, 06:09 PM
If my reciever is not putting out a neutral signal (as in it's not on), my Castle controllers will not initialize. They will give you the first few tones, and maybe count cells, but won't do the final ready to go tones. The fan will keep running until the controller finishes initialization.
123revo
11.18.2008, 09:57 AM
so now the V3 is in and up and running like a champ. i fitted my hitech 645 mg servo for steering, however when i went to put the other 645mg for the throttle/braking the unit wouldnt initialize/arm at all. i reversed the channel and no luck either way. i put the original traxxas one back in, which i assume is a generic hi-tec maybe and it works like normal. i would understand if the steering servos didnt work, but they do. so i am not sure whats up with the throttle servo... any ideas? i even lengthened the arming time to 2 and 2.5 seconds also. no luck. for now the generic traxxas one will stay in there until i figure it out.
pasan
I <3 RC
pasan's Avatar
11.18.2008, 10:50 AM
Is it a working servo?
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
123revo
11.19.2008, 02:25 AM
yes both work fine and are brand new, even swapped the working steering one with the one i wanted to use for the throttle/brake...no change.
pasan
I <3 RC
pasan's Avatar
11.19.2008, 04:51 AM
I'm not too familiar with how mechanical brakes work in parallel with an ESC. Do you use a Y connector?
AX10 RTR - Stock :D
