phatmonk
RC carbon junkie
phatmonk's Avatar
09.18.2008, 03:55 PM
Ok I just got my RCM Revo Brushless motormount that I am useing in my Slayer conversion and I just need a picture of how the mount is assembled Please Help..And do I just turn the adjustment for the 2 speed counterclockwise to lock it into 2nd gear.And how many turns?And does this enable reverse to be used?Thanks guys couldnt do it without ya
bruce750i
bruce750i's Avatar
09.18.2008, 04:10 PM
phatmonk: To lock it in you will have to take apart the transmission and modify it.(http://www.rc-monster.com/forum/show...ight=gear+lock) You don't have to lock it in if you keep your brake servo stock and don't care about reverse. RCM motor mount IDK if they are even the same as when i bought mine. Three pieces?
09.18.2008, 04:41 PM
I don't have a picture, but if you blow this one up (from the storefront), you should be able to assemble it from that:
Adjusting the shift screw will NOT totally eliminate first gear. Shifting will be a lot sooner, true, but not instant. And it won't allow reverse or motor braking. Locking into second would be the only easy/free method to allow reverse and motor braking.
Be careful if you do decrease the shift point though, if you go too far, the set screw, spring, and little ball bearing will fall out. It's not good for the gears to have those loose parts floating around in there!
phatmonk
RC carbon junkie
phatmonk's Avatar
09.18.2008, 09:01 PM
Thanks Guys I found Brian Gs thread on locking the second gear.Very stoked with the help I continue to find in the RCM forums.Why doesnt the mount come with at least a photo of a assembled mount?
