Jabe
10.01.2008, 10:30 AM
I tried it today and it doesn't work :( - The front brace stops the motor 1515 mounting properly...
Anyone need a 46 centre spider diff! Arg
just wanted to show you that its possible to mount motor in front, just need to use bigger gears.
i have 51t in spider and 12t in motor, cant use any smaller with brakes, it allready needs smaller brake disc, as its rubbing on it.
theres less than 3mm betwene motor and brace.
with 51t spurgear, motormount needs few washers underneath, to clear.
