TDC57
TDC57's Avatar
10.01.2008, 03:13 PM
Thanks Neil and James.. I’ll look into the radio’s tonight..
Quick recap:
• Got the frame (check)
• Got two 6mm paint ball guns firing 20 rounds (check) weighing 4lbs
• Got the articulating firing mount (check)
• Got 8 rockets and 2 set of pods (check)
• I got the firing system recommendation (check)
Need the following:
I still need help with the deploying the rear smoke
I still need help to figure out a way to keep the rockets in the pods while bashing the truck
I need to find and buy a 6+ channel radio system
I need to buy another 6mm paint semi auto paint gun
I'm pretty sure I’ve figured out already know how the doors will work (drew if up last night). It will be basically controlled like Linc ref above (linkage and servo).. I'm a little lost on the rotary thing (sorry)..
I plan on bolting the rocket pods to the inside of the gull wing doors, that way when they raise up so do the rockets.. OOoo I can see it now… LOL.LOl.. depends on the weight ?? TBD
My 6mm Semi Auto paint gun only holds 10 rounds (bummer) but its all electronic so I’ll have the options of using either a crude linkage system or I’ll pay BrianG for some programming time.. I even (I think) figured out a way to install two of them, so between 8 rockets and 20 rounds of paint I should be just about good to go.. LOL.LOL
Another thing I still need to figure out is deploying smoke out the rear (some camouflage and confusion screen ).. I know planes have something like a smoke bottle but I'm not sure I can use that on a truck.. So again (any help) is deeply appreciated..
GREAT PULL and at $45 bucks a pop I got two (gave me more ides / Just incase the gull wings fail) Thank you SIR…
Should be a total blast at the next so-Cal bash… (literally!)
Nothing!.. Hahahahaaa..
10.01.2008, 03:20 PM
Smoke...
Ignition is the only issue... But not sure why you couldn't use an electric igniter...
http://chemistry.about.com/od/demons.../smokebomb.htm
10.01.2008, 03:24 PM
PS I think you can do a google on e-matches to look at ignition options.
Takedown
WARNING: May become violent.
Takedown's Avatar
10.01.2008, 03:28 PM
Yep, I definately plan on watching this build. We need somthing out of the ordinary like this once in awhile here on rcm...
RIP- Tammy (9/14/08)
TDC57
TDC57's Avatar
10.01.2008, 03:31 PM
Thanks TD / just trying to keep up with the (Lincpimp's of the world)
TDC57
TDC57's Avatar
That's cool Arct1k.. I don’t know how you find these things but you’re the Man..
Although I'm checking the plane sites for a canisters type, if planes have them there has got to be something I can buy ??.
Thanks for the throwing them out Sir.. Please keep them coming..
DickyT
10.01.2008, 03:29 PM
great project.
My question goes to rocket flight path with no fins to aim them, or will you be doing something like that FFAR's (folding fin aerial rocket) that they can mount to attack helis?
TDC57
TDC57's Avatar
10.01.2008, 03:34 PM
Originally Posted by DickyT View Post
great project.
Hay DickyT,
I’ll be using a folding fin system.. I got a heavy duty air cleaner and plan on using the flutes of the filter as fins for the rockets, they fold onto the rocket and then slide into the pod. In theory they should expand once the rockets leave the pods.. In theory..
If they need help re-xpandning after they leve the pod then I / "WE" will need to think of somthing.. Hoping the above works..
10.01.2008, 05:00 PM
Originally Posted by TDC57 View Post
Hay DickyT,
I would find some sort of thin spring metal that can be used to make fins. That way they can be folded up and will hold the rocket in the tube. Problem will be finding something thin and springy, but not too strong that the rocket will not come out of the tube when powered.
jefierro
jefierro's Avatar
10.01.2008, 03:51 PM
lol this reminds me of a project i wanted to do when i was 10, boy is great to be an adult, you get to do those things you dream about.
When i was a kid i build a rocket launcher with a wired launch control panel i used very thing copper wire forming a spiral,(resistance) then let true some amount of current to fuse the wire this ignited the "rockets".
also you might consider an auto destruct mechanism lol
E-Maxx 3906 FLM-RPM HV4.5 4s
E-Maxx 3905 Trail-Crawler E-Monster Torque 2s2p
Kyosho ZX-5 SP Mamba 6900 2s
  Send a message via MSN to jefierro
cornolio
cornolio's Avatar
10.01.2008, 04:15 PM
cool project.you have to get this done before the bash,i have to see this
xray xt8 MMM neu1515 1y
hotbodies ve8 novak HV 6.5
hotbodies cyclone tc
mugen mtx4(nitro)
lst2(conversion ongoing)
  Send a message via Yahoo to cornolio
10.01.2008, 04:27 PM
Here you go:
http://www.regin.com/rcsmokeacc.html
10.01.2008, 04:39 PM
even easier! TowerHobbies! http://www3.towerhobbies.com/cgi-bin...?&I=LXFT71&P=7
brushlessboy16
brushlessboy16's Avatar
10.01.2008, 05:56 PM
copied and pasted from tower hobbies
NOTES FROM OUR TECH DEPARTMENT
Smoke-Equipped Planes are rapidly becoming more popular with the show team-
type demos that are all over the country. If you don't want to mess with
compicated plumbing, you need a smoke cartridge like the Smoke-Riter.
FEATURES: Produces approx. 3 minutes of dense grey/white smoke No need for plumbing to exhaust, messy fluids, or residue clean-up Mount to fuselage by using a clamp (not included) in marked locations Only. Light fuse to begin smoke reaction.
INCLUDES: One Smoke-Riter Cartridge w/Ignition Fuse
SPECS: Length: 6" Weight: 6 oz (including light blue wrapper) Diameter: 1-1/2" Fuse length: 2-1/2"
COMMENTS: Smoke release holes must face ground. Smoke is TOXIC. Avoid Prolonged Exposure. Clamps to hold cartridge to the fuselage (try a hardware store).
we dont want our fellow forum'ers to die
10.01.2008, 05:21 PM
On the door opening front, have you concidered these?
http://servocity.com/html/servo_actuators.html
They have much smaller versions coming soon.
