TDC57
TDC57's Avatar
10.01.2008, 03:34 PM
Originally Posted by DickyT View Post
great project.
My question goes to rocket flight path with no fins to aim them, or will you be doing something like that FFAR's (folding fin aerial rocket) that they can mount to attack helis?
Hay DickyT,
I’ll be using a folding fin system.. I got a heavy duty air cleaner and plan on using the flutes of the filter as fins for the rockets, they fold onto the rocket and then slide into the pod. In theory they should expand once the rockets leave the pods.. In theory..
If they need help re-xpandning after they leve the pod then I / "WE" will need to think of somthing.. Hoping the above works..
Nothing!.. Hahahahaaa..
10.01.2008, 05:00 PM
Originally Posted by TDC57 View Post
Hay DickyT,
I would find some sort of thin spring metal that can be used to make fins. That way they can be folded up and will hold the rocket in the tube. Problem will be finding something thin and springy, but not too strong that the rocket will not come out of the tube when powered.
