JThiessen
JThiessen's Avatar
10.10.2008, 09:29 AM
I did my Neu with the Aluminum tape last night. Worked fairly well. I took a file to the edges, and it looks factory installed. I did however find a small problem. I had removed the Neu/MMM a week or so ago and set it on the bench. When I started doing the taping, I initially picked them both up and moved them to my work spot - assuming they were still connected. After a little turning and looking at it, without thinking about it, I set the MMM aside. Well, after I finished the tape job, and was admiring my work, I noticed that every one of my bullet connectors was missing!
Sure enough, they were still attached to the MMM. Looks as though nothing stuck to the bullet side on all three. Lesson learned, all the money in the world cant buy a good enough soldering iron to make a bad solderer a good one.
Brian, my offer......please........
10.10.2008, 09:47 AM
...Brian, my offer......please........
JThiessen
JThiessen's Avatar
10.10.2008, 11:06 PM
I drill your holes for you - you do my wiring!!!
