Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
10.08.2007, 08:35 PM
Originally Posted by mkrusedc View Post
Must be something in the LA air.
or something to do with muppets
We need to get back on subject. Sorry
NECESSITY IS THE MOTHER OF INVENTION
Emaxx Tranny slipper modification (Strobe like)
http://www.rc-monster.com/forum/showthread.php?t=9341
homemade sprong
kona
homemade sprong - 10.10.2007, 02:08 AM
I posted this on another forum, but thought it'll be relevant here also. Hope that is ok.
I didn't like how the stock spring sits a little crooked on the pressure plate and since the Strobe Sprong isn't made anymore, I made my own. Best of all, it is made from 'bonnet packing' available in the plumbing section at Lowes or HD for 2 @ $.79.
I used a #8 nut to help center the rubber ring. It is just the right size to fit over the input shaft and fit inside the rubber ring.
I used an extra slipper pressure plate turned around. The tapered shape of the pressure plates also helps center the rubber ring. I also tried it with a fender washer and it works fine too. It's just harder to center.
I'm using a strobe slipper, but it should work just the same with the stock slipper. I don't think the inner nut is totally necessary, but it does help keep everything centered . I'm running it about 1/4 to 1/2 turn out from locked and it seems to work pretty well on a 8xl emaxx.
mkrusedc
NeuMaxx
mkrusedc's Avatar
10.19.2008, 06:21 PM
Just a quick noobish question. To install the sprong on my E-Maxx I just remove the spring and put it against the pressure plate right?
plettenbergs
plettenbergs's Avatar
10.19.2008, 06:38 PM
i only use the strobe sprongs...they work great and look cool...they are also worth the gingle!!
George16
Supermaxx
George16's Avatar
10.19.2008, 06:43 PM
I had been running the same setup for a while now and it's keeping up with the 1515 1Y on 6S.
Yes.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
mkrusedc
NeuMaxx
mkrusedc's Avatar
10.19.2008, 07:00 PM
Thanks. That is how I did it. I did not know that the sprong plate is threaded. Now I understand ClodMax's post that he could make adjustsment by hand. Kinda cool!
George16
Supermaxx
George16's Avatar
10.19.2008, 08:21 PM
Mark, some didn't like the threaded plate because it loosend itslf and messes the stock slipper plates. Hopefully, your experience will be better. If I were you, I'll drill/bore out the threads so it would just slip into the shaft and use a nylock nut to keep the plate in place.
Revo with OS .18TZ
