Unsullied_Spy
Unsullied_Spy's Avatar
10.27.2008, 01:14 AM
I plan on putting 30 series Torque wheels with Badlands on my future CRT once Mike gets his new Chassis in stock. They're 5" so it'll give another 1/2" of ground clearance, just gotta gear down a little to handle the larger tires. I use these wheels/tires on my Rustler and they are the best!
david lamontagn
10.27.2008, 08:31 AM
Gear down is not the problem, the main problem will be the hub, knuckle and bearing tohandle this side load cause by the largest tires.
Unsullied_Spy
10.27.2008, 11:30 PM
Is it that big of a deal on the CRT? I run them on a Traxxas Rustler and it seems to be holding up to them pretty well. It would be nice if Mike would make a kit that uses 8mm axles and an aluminum knuckle with big bearings and came with 17mm hexes--that would be a popular kit I'm betting.
david lamontagn
10.27.2008, 11:51 PM
+1 and i would be the first to order it
Unsullied_Spy
10.28.2008, 12:07 AM
Funny, I just thought it up at work today I should PM him about it and see if he could do it...
yappa
10.28.2008, 12:21 PM
david lamontagn
10.28.2008, 10:42 PM
What's this adapters yappa??????????????
