10.30.2008, 11:24 AM
Also I will list the brands of lipos I have already repaired, and should not have any trouble with.
Any enerland cell based pack (ie, polyquest, polyrc, flightpower, neuenergy, hyperion, etc)
Maxamps (all)
Zippy
Thunderpower
Venom
Most chinese packs
All of these use aluminum or copper tabs and I have the required products to solder to them.
I generally protect the ends of the lipo with something solid, such as thin sheet plastic. I also completely wrap the pack in clear tape. This holds everything together, prevents cell shifting, and gives the pack a bit more protection. I use black shrink as I can get it easily, and most like the look of it.
Note: I recently had a protek pack sent to me with a puffed cell. They encase the contact end of the lipo with some sort of nasty glue. I was able to remove enough of this stuff to access the solder tabs and balancer wiring, but it was a bitch. So I charge a bit more for those packs and cannot gaurante that I can fix them, as the glue is much stronger than the al tab. This is delicate work and that glue needs a bit of muscle to remove.
auto2
11.22.2008, 02:15 PM
i have a 4s 3700 i got from mike that says anyrc.com on it that has a strange proble,
everything seems normal.pack is hard and flat,charges corrctlly and is in balance butit has no power at all. if buggy is geared for 40 mph with this pack it will go 10mph full throttle. wont even rev up enough to have trouble making full speed turns on the street it is that slow. what you think?
11.22.2008, 02:31 PM
Do you have another lipo to try? May not even be the battery.
How do you charge the lipo? What balancer and charger do you use? Do you have a volt meter? Also what motor and esc are you using?
BMX_LEGACY
11.26.2008, 06:06 PM
lincpimp ygpm
01.06.2009, 11:05 AM
Just figured that I would update this thread with my recent repairs.
I have now repaired all of the various hard cased lipos. So I am familiar with how they are setup internally, and most inportantly, how to get the cases open with out damaging the case or internal wiring. So heres a list,
All losi hard cased lipos
Enerland hard case
Orion/kokam hard case
Trakpower
And the cheaper ebay chinese cell hard case lipos
Not sure that I put this anywhere else, but please post info here or pm me. I leave pricing to pms, but repairs usually take a day or so and I can ship back the lipo. Payment can be made via paypal or thru MO/cash.
And as always I am interested in buying damaged packs that you may not want, I only ask to have a look at them before we settle on a price. I will also pay shipping for this.
Thanks for all the interest, and I hope I am providing a somewhat useful service...
Lipo repair feedback
ilpufxit
ilpufxit's Avatar
Lipo repair feedback - 02.14.2009, 12:40 AM
I just got my lipos back. I'm impressed, they look like new, they're balanced and ready to use.
I spent under $70 with shipping and the repair, easily worth it when my other option was to junk the packs at over $200 each.
02.14.2009, 05:12 AM
Looks like I got something right....
Jeremy1976
02.17.2009, 12:23 PM
Very cool that you do this for the forum here! Just sent you a pm regarding rewiring a pack for me. Jeremy
02.17.2009, 02:59 PM
No prob, hate to see people throw away good cells, and money!!!
himalaya
himalaya's Avatar
04.01.2009, 05:44 AM
Maxamps (all)
Hi Linc, are Neuenergy Packs actually using Enerland cells? Note their capacity numbers are completely different to the ones listed on Enerland's website for their XP XQ cells.
....What a Blue Sky....
04.01.2009, 11:36 AM
I always thought they were enerland. They are assembled similar from the outside, and they definitely have tabs on each end, and only enerland and elite do that.
I have not pulled any neu packs apart yet, no dead cells so far.
In fact I have not dealt with an enerland based pack that had anything other than physical damage, no qc issues, tabs falling off or much else.
I did have one trakpower pack that smoked a bit during a charge, turned out a balancer wire must have been bad (maybe pinched and cut thru most of the strands?), and it got hot and melted the insulation. I popped it open and changed the wire out, no issues since...
Otherwise my experience with enerland cells has been great. I have made and reconfigured a ton of packs by them, with great results.
himalaya
himalaya's Avatar
04.02.2009, 12:54 AM
Surely they are great packs, but seems like there are more good cell manufacturers than just Enerland.
I just paid some small attention to the details, what I found is FlightPower, PolyRC & Hyperion's packs all have capacity numbers accurately match Enerland's cell series, say 30C XQ series, 700/1200/2000/3200/4500 mAh,or twice the number for a 2P config. But NeuEnergy has 800/1500/1800/2100/2500/3300/4100/5000, none of them match Enerland's cell.
Also there are some Chinese LiPo maker do their cell's having tabs on both ends.
04.02.2009, 09:50 AM
Enerland do offer quite a few different cells. I have found that the 5000 30c cells are offered in different lengths, a short and a long. These cells are the same with all of the mfgs that offer them.
As far as the tab on each end goes, I pulled my first rhino pack apart last night. It certainly has the enerland style cell layout, but is assembled differently. None of the std enerland markings on the foil either.
04.02.2009, 10:02 AM
Question time...
Who do these belong to? Real name is Michael Chin...
And the lower pack is a great example of a puffed cell. I do not think I have ever seen a cell that puffed...
