Originally Posted by crazyjr
Sorry pimp, but i got to show this to you, I did aneagletree on my SRT w/VXL on 3s and 2s and here is the wattage graph on it. as you can see it nearlt pulled 1150 watts in a truck less than half the size of the Emaxx/E-revo.
http://s187.photobucket.com/albums/x...and2swatts.jpg
Do you have any average numbers for the run?
I was only trying to say that a 1521 will be able to handle higher gearing for longer than the vtwin setup will. I know the vxl motor is decent, but is designed for a 10th scale 2wd truck. Plus it will get hot with alot of load, no way to get around its efficientcy. The Neu motor design is superior to a feigao. I am sure that a 1506 of similar spec will outperform the vxl motor.
