edep345
11.14.2008, 11:28 PM
Make sure the trimsetting on the transmitter is set to the center, then run the calibration setup. You know full throttle, turn on the MMM, beeps, full brake, beeps, neutral, beeps. Then you should be fine. But make sure all of the trim settings on the radio are at the center position while you do this.
I did this with the dials on the tq-2, and also manually with the spectrum, it just makes that initial multi-toned beep--and then keeps flashing the yellow and green
help?
edep345
help? - 11.15.2008, 12:24 AM
-thx
