Rc18
mriccucci
mriccucci's Avatar
Rc18 - 11.19.2008, 12:27 PM
Ok so i picked an rc18 off ebay, its a roller and im planning on either using the MM i have, or picking up a micro-pro, suggestions here?
I am also wondering what my motor options are and what i should use for a battery, i was going to go after the truerc 2200mah 7.4 batttery, not looking for insane speed just yet, just a basher so mess around with.
t-maxxracer32
t-maxxracer32's Avatar
11.19.2008, 12:29 PM
mm esc would not overheat and would pretty much have no problems but it is on the big side for this truck. you can make it fit though.
as far as a motor goes... i have not really found much success in the castle motors... they overheat quite often. id go with a hyperion motor. mini neu if money doesnt matter.
azjc
11.19.2008, 06:52 PM
IMO use a Mamba Micro Pro ESC and for a motor I agree not to go with a Mamba but a Hyperion yc-22 long or a neu 1105.....I have run a 18t with a 3s 1500 pack with a hyperion 4400kv motor...I have had thought of going to 4s someday
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
11.20.2008, 03:31 AM
just wondering....what gearing and wheels do you use?
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
YogyBrushless
11.20.2008, 05:12 AM
just a quick question guys (hopefully not jacking the thread), there is a 0.3 mm difference in the shafts of cc mamba motors (2.0 mm) and the neu 1105 motors (2.3 mm). if i have pinions for the cc motor will be hard fitting them to the neu motor shaft ? (i.e stretching the pinion hole from 2.0mm to 2.3mm) ??
