speedracer1129
11.30.2008, 07:55 PM
dirt,
On paper, the 1515 on 10S will pull about 61k rpm. It won't pull that in the car under load so I will be in the 60k max spec. I am shooting for about 50k under load. I am most worried about the ESC than anything else as I hope it will give me the amperage I need!! I know I should have used the HV110, but I got the HV85 in a deal brand new.
Takedown
WARNING: May become violent.
Takedown's Avatar
11.30.2008, 07:59 PM
All in all Im wish you the best of luck with this. I expecting 90mph+.
RIP- Tammy (9/14/08)
speedracer1129
11.30.2008, 10:01 PM
Thanks Takedown!! I appreciate it!!
dirt101
dirt101's Avatar
11.30.2008, 08:00 PM
i think I read somewhere that the 1y pulls around 60 amps at 60mph on 6s in an emaxx. so im "guessing" with the extra voltage, lower k/v motor, and a more aerodynamic truck the 85 amp esc shouldnt be a problem.
rustler, lx2e, xxt cr
speedracer1129
11.30.2008, 10:05 PM
dirt,
That is all relative to gearing. I am used to seeing 150-180 spikes in high speed 4S-5S setups. I am hoping the HV setup will calm it down to lower spikes but we will see...
azjc
11.30.2008, 11:09 PM
my first thought was you be exceeding the 85 amp limit of the ESC but its a conservative rating it should be able to take more than 100 amps IMO. I like the idea of going with a higher torque/lower kv motor and getting your speed with gearing. If you only increase your battery voltage and leave everything else the same your amperage will increase
speedracer1129
12.01.2008, 11:19 AM
I understand AZ. Maybe I worded that comment wrong. I have not tested this setup at all yet. I saw those numbers on other vehicles that I have done. What I meant to say is that I hope with a HV setup like this I don't see those numbers!!
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
12.01.2008, 05:58 AM
Sweet, whats the chances of a vid
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
Semi Pro
Semi Pro's Avatar
12.01.2008, 09:04 AM
very cool truck, i cant wait to see a vid too
speedracer1129
12.01.2008, 11:21 AM
Very bad weather here in Miami. It has been raining alot since Saturday night. I hope before I leave to Cali next week!!!
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
12.01.2008, 12:07 PM
sick!!! and after you get done with the speed runs and such you can add a few body posts/fonrt /rear bumpers and BAM! you have the first ever losi sc8ight....
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
12.01.2008, 01:05 PM
FYI: I ran the 1515 2.5d on 10s in my Ultra GTP and the motor handled it fine. The HV110 ESC handled it ok for a while, but one of the input caps literally exploded spattering the windshield with bits of goo. Only 1 of the 6 caps did that - the rest weren't even puffed. It still ran ok, but I sent it in anyway despite it will probably void the warranty being it was used out of spec. If it comes back, I can hook you up with a good price for it if interested - and it I have an extra pistix to go with it if needed.
Good luck! I am done with the speed thing. It was simply uncontrollable and wasn't very fun.
bustitup
12.01.2008, 03:22 PM
Lol.....that Car WITH THE LID OFF Looks Like A Bomb
speedracer1129
12.01.2008, 03:50 PM
Scary ain't it....
speedracer1129
12.01.2008, 03:49 PM
Brian,
I thought you never got a chance to run it?? Did you get any info on it like speed, amp draw, etc. ??
