himalaya
himalaya's Avatar
12.01.2008, 04:23 AM
Yes it will, just like the MM handles 4S perfectly with a BEC installed. I believe the major difference between Sidewinder and its bigger brothers is the number of MOSFETs mounted, which affects current spec, not voltage.
....What a Blue Sky....
Matthew_Armeni
Matthew_Armeni's Avatar
12.01.2008, 01:14 PM
Well if that's true, maybe I'll try 6s on it....
  Send a message via AIM to Matthew_Armeni
DickyT
12.01.2008, 01:58 PM
that will not go so well I think... I plugged 5s into mine after having GriffinRu
stage 1 mods done and it went up in a ball of flame.
himalaya
himalaya's Avatar
12.01.2008, 11:26 PM
I have to say you are so brave, man.
stompingpede
12.02.2008, 12:05 AM
5s worked on my mini rage when the pack was at nominal voltage.18.5. when i peaked the lipos 21v, it stuttered and the smoked. ran 73mph in 1.7 seconds using tekin mini rage with 8.0kv mini motor.
12.02.2008, 01:05 AM
Do you know that's 148000rpm?
stompingpede
12.02.2008, 05:02 AM
in drag racing it never reaches full rpm. over gearing actually makes it take of faster, so im guessing it only saw 50,000rpm
Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
12.02.2008, 01:52 PM
It will work on 4s with BEC and no cap installed, but we will not cover the ESC under warranty if something happens when running on 4s. Make sure your batteries are more than capable of the current draw. 20C rating and 1500mah+.
Joe Ford
Product Specialist
