SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
12.05.2008, 01:20 AM
Still, because it is feigao, there's no doubt in my mind that you would have to go way down in cell count or get a super, super low kv version in order to get temps within range of a dinky Novak motor that is properly geared. And by the time you do that, surely it it will less power than the novak motor. This is the case with most feigao motors ive tried. But you never know. Maybe the 580 feigao motors are big enough so that way below its recommended voltage input, it will not overheat under the conditions that 1506 size neus typically handle.
Area 52 Ranch Raceway
T.R.C.R.
12.05.2008, 01:45 AM
Most likely for the boat guys. With water cooling feigaos never get hot and can put out some serious watts. Still ineffecient, but a damn good value. Boat racers do 3-5min heats so no real issue.
