Semi Pro
Semi Pro's Avatar
12.07.2008, 05:44 PM
very cool looking project
Ryu James
Ryu James's Avatar
12.07.2008, 07:36 PM
these are all good tips about the kickup. thanks. that has been my main concern with this project but i think it will work out ok with the adjustments i have made so far but i will be sure to post how it works out.
my losi 8t has kickup on the chassis too. according to Tekno RC the RC8T has 7* of kickup in the front. but i have measured the angle on the stock chassis and the Tekno RC8 buggy chassis. the stock is at 7* and TEknos buggy chassis has only 5*. not very much at all. i think it will do ok as long as the suspension moves in a rearward motion as i stated previously. almost all chassis' have between 5* and 10* of kickup. unfortuantely to get a carbon fiber piece with this angle companies would have to charge thousands to make a custom mold and really none were willing to do it unless it was going to be a patented item that would be mass produced.
basically my chassis is a identical to a Tekno RC chassis. it is designed strictly after theirs. however, Tekno has already made a RC8T chassis that is at production now and will be avail soon. theirs is slightly different than mine though. instead of having the servos on each side of the chassis like mine theirs will both be on one side. basically their layout is identical to their 8T design while mine is more like their Jammin and Mugen design. going with the 8t style layout would have been easier but i like the Mugen and Jammin layouts better because they are better balanced, put more weight forward for better handling, and require less use of wire between the motor, esc, and battery resulting in less resistance. you can see these different layouts on their site www.impaktrc.com or click on the links below.
if this CF chassis doesnt work out due to the lack of kickup on the chassis i will just buy Teknos RC8T conversion when it comes out in the next couple of months.
http://www.teknorc.com/images/TKR4014-close.jpg
http://www.teknorc.com/images/tkr400...ew_close_s.jpg
http://www.teknorc.com/images/TKR4007-close.jpg
Jammin SCRT10 Neu 1512 1y
