Custom Carbon Fiber Brushless RC8T Pics
Ryu James
Ryu James's Avatar
Custom Carbon Fiber Brushless RC8T Pics - 12.06.2008, 10:54 PM
So i started on this custom RC8T a while ago and i am finally getting close to finishing her. Most the time has been spent waiting for the carbon fiber sheet to be made. I had a sheet of 5mm, 1k tight weave, unidirectional laid, carbon fiber made for the chassis. it is by far the strongest, best looking carbon fiber i have ever seen. i can stand on it on top of 2 cinder blocks without it hardly bending and i weigh 200 lb. i cut the chassis from the 5mm sheet using a dremel tool only. areas of the chassis have to milled out which i have been able to due using dremel carbide tungsten bits. this carbon fiber is tough. i tried using regular bits to mill out the areas and they just melted. they would get too hot. the carbide bits have held up will though.
for the conversion i am using Tekno RCs Mugen conversion CVDs, battery tray, radio deck, servo mounts, and motor plates.
due to the layout of the CVDs the stock front chassis brace wouldnt fit so i used the shorter one from the RC8 buggy.
the RC8T has a lot of blue alum. parts on it so i decided to continue with that theme and add a lot of blue upgrades to it. i like how it is turning out so far. not quite done so the pics are of the process so far and i have just laid things out on the chassis so you can see how the setup will be. i will post more of the finished product later. hope you enjoy.
asc21
asc19
asc29
asc24
asc28
asc20
asc27
asc25
asc26
asc23
Jammin SCRT10 Neu 1512 1y
Ryu James
Ryu James's Avatar
12.06.2008, 11:02 PM
asc22
asc18
asc17
asc16
the motor sits very close to the MMM so i am able to solder only one bullet for maximum juice. havent solder the bullets yet but you can get the idea from this pic.
asc15
asc13
asc14
asc9
carbon fiber mudguards too! notice how the mudguards are normal weave carbon and see how the chassis' weave is way smaller and tighter. this increases strength tremendously.
asc8
asc7
Ryu James
Ryu James's Avatar
12.06.2008, 11:09 PM
some pics of the body. i am waiting on some scoops from www.oocrcracing.com to add to the body for cooling. check out their site. they are a pretty sweet addition to any body and you dont have to cut stupid holes in random places to keep your gear cool. you actually have functional cooling ducts. be sure to view the gallery.
asc11
asc10
asc6
asc5
asc3
asc1
a custom fit front bumper from the Jammin X2
asc2
asc4
A RC Dude
A RC Dude's Avatar
12.06.2008, 11:27 PM
wow lol
trev3813
Dsm needed
trev3813's Avatar
12.07.2008, 12:09 AM
Originally Posted by A RC Dude View Post
wow lol
What he said, is it the pics or is your rear camber off?
shizzon
shizzon's Avatar
12.07.2008, 12:14 AM
so your going to be using mech brakes without and electriclutch? are you going to turn the brakes off on the MMM? or both? And did you just thread the components into the chassis, as there are none on the underside of the chassis. Carbon fiber is definately a wonder material as long as it is used correctly, and that chassis is sure to have all the strength you will need.
Very nice build!!
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
12.07.2008, 12:25 AM
i see you spending much money on r/c lately, and I must ask: Can I have an allowance? My grades are good and my chores are all done and I promise........................
Seriously though, nice build, I cant tell, did you get it to kick up in the front or is it flat?
Takedown
WARNING: May become violent.
Takedown's Avatar
12.07.2008, 12:39 AM
Absolutely sick.
RIP- Tammy (9/14/08)
lutach
lutach's Avatar
12.07.2008, 01:10 AM
Looks nice. What was the weight before and after the CF chassis?
brushlessboy16
brushlessboy16's Avatar
12.07.2008, 10:50 AM
The Camber is off cuz the truck is not done.(Center diff is not mounted, etc)
That is one sweet looking ride!! Makes me wonder about carbon fiber.:)
12.07.2008, 12:54 PM
Truly a work of art. Nice job.
Ryu James
Ryu James's Avatar
12.07.2008, 01:05 PM
Very nice build!!
i will be using mechanical brakes and have the braking and drag completely off on the MMM. but i will use a longshank pinion instead of the elektriclutch as i like direct-drive better. this is how my current setup is on my 8t.
the reason there are no holes in the chassis is cuz i have not finished the build yet. i will post pics when completely finished but there will be countersunk screws in the chassis just like any other chassis.
Ryu James
Ryu James's Avatar
12.07.2008, 01:18 PM
dude! you dont even wanna know. lets just say that my bank accounts used to have a nice surplus and now they are virtually empty. it might be a couple of months before you see my other builds completed.
as far as the kickup, unfortunately i couldnt find anyone that could make the sheet with the angle needed. the place i bought from (dagraphite.com) could have made me a sheet with a 20* bend only. i was going to do that but i bent an aluminum chassis i have to see how it would work and 20* was way to much. the kickup on the RC8t is about 5*-7*. plus i did some reading up on the kickup and why it is there and the main reason is not cuz that chassis needs but it is used for anti-dive and the path that your suspension travels.
like in the rear you use anti-squat. anti-squat causes your suspension to travel at a rearward angle when you hit bumps aiding in the handling of your truck. zero-squat is when your suspension travels directly straight up and down. this is also acceptable. pro-squat is when your suspension travels forward and this is unacceptable. the handling would be bouncing all over the place.
the same holds true for the front of the truck except it is called dive instead of squat. and the desired settings are similar. you basically want anti-dive up front. this aids handling and also prevents your truck from nose diving when you hit the brakes.
the kickup on the front of your chassis basically provides this anti-dive setting. however, it is possible to get on a flat chassis too. what i did was buy a better hingepin brace setup from Reckward Tuning that has the plastic hingepin bushings with the holes in them that can be used for different angles. i used the bushings to create the steepest angle possible actually resulting in a rearward suspension travel almost identical to that of the stock setup. so it should work out i am hoping. as soon as i drive the truck i will post and let you know how it does. i sure hope it does. i have put in too much work for this not to work now.
Ryu James
Ryu James's Avatar
12.07.2008, 01:20 PM
i havent weighed the chassis' yet. the CF is just a little lighter i can tell when i hold them. had i gone with a 3mm or even 4mm the weight saving would be more substantial but the 5mm is only slightly lighter than a 3mm milled alum chassis.
Ryu James
Ryu James's Avatar
12.07.2008, 01:22 PM
rear camber is off cuz i am not done building yet and havent made final adjustments. these are just some pics prior to finishing the project.
