What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
12.11.2008, 11:24 PM
I would trace the outline of the chassis on the aluminum plate, then place the motor, CD, BT within the outline and move them around until you have a setup that you like. Then trace around everything and mark the holes to be drilled. If you wanted to tape everyting down, you could even check the balance before drilling anything.
