I run 2 sets of rear Jato Anacondas on my rustler, the offset will be "off" (not equal front and back, rear will stick out more..its not that bad but they are off unless you get the FLM extended front aarms. This company is making foams in offset for them http://www.jacoracing.net/newitems_foam_rubber.html
Ok, that is helpful for sure. I really want some of those Jaco's for aspault, but i do see alot of offroad so i do need some 30's for that in Dirt Hawg tread. I could use some flm extended arms up front, they would also double as a wheely counter-weight.
