azjc
01.01.2009, 03:31 PM
Well I have to bite my tongue....... I got the Rivergate 45, and ended up returning it. Too industrial. (never thought I'd say that!)
And I figured out I'll only be charging at 8 amps per port, so it was way overkill. I instead got a 30 amp "Power Force" from HobbyLobby for $80, don't have it yet but I'll report back on that.
As for the Duo, my only major complaint so far is the weakass chime. Not a huge deal, but I was used to using a friend's PolyCharge 4 which had a chime that could be heard about 2 city blocks away over traffic noise....
AND please I need a little help with charge rate settings, I bought the adapters for charging my DX3.0 and my receiver cells, all are 2000 mAH NimH, what would be a good amp setting for those?
1 amp enough for a semi-quick charge? I have the trickle setting at 50mA, the lowest- sound OK?
what do you mean by too industrial?...was it too heavy?
