Semi Pro
Semi Pro's Avatar
01.09.2009, 05:42 PM
Originally Posted by portyansky View Post
I was told that the gears in the Slayer tranny are geared higher then the Revo tranny. Anyone know if this is true? If it is, I wonder if it would be beneficial to switch my Revo gears for the Slayer gears.
Has anyone tried this?
Sorry if this has been posted somewhere allready.
its great, with the slayer tranny you have alot more options for gear ratios
with my 1515 2.5d on 5 cell i had monster bottom end but was limited to about 35mph with the proline tires
with the slayer tranny the top end is about 45mph on 5 cell
and i have almost no mid throtle lift so it worked out great in my race revo.
the only down side is traxxas hasnt put out a diff for the slayer tranny
portyansky
01.09.2009, 11:51 PM
Did you lock the tranny, or are you using the 2 speed setup?
2 speed
did you get the slayer tranny case as well? I hear a cd is comming.
What gearing are you using? How are your temps? And are you using the wide ratio?
Thanks.
