Krawlin
Got brushless?
Krawlin's Avatar
01.13.2009, 07:36 PM
I suggest you sell the MM while it is still alive and invest in a MMM- you won't regret it.
Nah, I want to see if I can get this thing to work. Not just going to take the easy way out this time.
it is your connectors, i told you that already, silly
Yeah, yeah..... I just hope the new connectors fix the problem so it wont happen again for however long the MM is around before it gets fried from by my motor.
I had the same issue with 2 of my MM's awhile back. Solved it by disabling the on/off switch all together and bought my first set of TRX plugs to replace the deans. I am very happy in doing so. They have more contact area, more confortable, more grip, no heatshrink...
How did you completely disable the on/off switch? Just solder the wires together like I did?
Monster GT Conversion
01.13.2009, 07:45 PM
^^^yeah, you can solder the wires together like you did, or put enough solder on the board to jump the gap between the two wires solder points. Either will "permanently disable" your on/off switch.
Tags
kick ass maxx
