Go Back   RC-Monster Forums > Support Forums > Team Tekin
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
01.24.2009, 01:56 PM
Didn't patrick or bernie say somewhere on these forums that amp ratings are kind of a "ghost" spec???? Like when novak says that their escs can handle 200 amps it's actually a lower value since there are other factors involved..???I'm not a full
Blown electrical gear head but I do know how to run efficient setups (thanks to you guys!!) but can someone back me up here about those over-stated amp ratings????
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
01.24.2009, 07:09 PM
Novak hvmaxx is rated at 400amps per phases, in reality it can manage about 70 or so.
Ghost spec isnt the term I would use, its just the manufactures spec of the FETS at 25*C with moving air for cooling; in reality our escs run more like 70*C without active cooling, so the fets wont handle the same current as they are rated for without overheating and thermalling the esc.
Another trick often used is to add up or multiply the amp ratings of the fets to get some kind of phantom rating up towards ~1000amps or so, but in reality the ratign of one fet is the rating of all of them.
Ask BrianG to explain derating curves, as that will give a true rating for the fets at any given temp- if you can find a part number for the fets uses in any given esc, you should be able to work out how much current it can actually handle in principle.
210*F doesnt sound too far fetched for RX8, especially as tekkin are a true racing outfit who use the more expensive components in their gear- hence the higher prices.
