01.25.2009, 09:54 PM
Check that two phases are not shorting across the heatsink...
AP Alex
AP Alex's Avatar
01.25.2009, 10:42 PM
Now, I'm really confused. I've tried a new out of the box esc, new firmware and all the correct settings, and got the same thing. Tried a new receiver and the same thing happened the only constant is the wires running from the esc to the motor. Nothing is touching as all solder joint have heatshrink over them and the connectors. Could the wire be bad? Where do I go next?
