Ya I have the tekno kit already, I also have the bore reducer already, I was looking at the novak long shanks.
Looks like you are on the right track. You can also use some spacers, maybe 5-6mm thick, to space the front of the motor mount plate towards the spur. That way you can run std length pinions and not place so much load on the motor's front bearing.
Ya I did see that mod somewhere im hoping I can avoid that. Guess I will find out soon, thanks for all the help.
