02.01.2009, 06:39 PM
If the charger still charges, just don't use the internal balancer and get an external one instead. Probably be easier and cheaper in the long run.
I liken a charger/balancer combo to a DVD/TV combo (or the older VCR/TV combos). A combo works great and is convenient....until the DVD player breaks, and then you're stuck using the combo as a TV only and have to use an external DVD player.
Wow, making do with you have... I usually do this myself, but...
Personally I would investigate the possibility of having it reapired. If it is less than a 40 buck fix it is cheaper than buying a lba 10 external balancer. An if you are savvy, you may get it fixed free...
