02.01.2009, 07:05 PM
TeknoRC, thanks for your support. I still didn't get the temps to go down even after putting the new clutch you sent to me. Like I stated in my build, my conversion's tranny is locked in 2nd gear. I'll probably try it again in the future but for now, I'll just enjoy running the truck using the long-shanked pinions I bought from your store.
If you have enough motor to not have startup issues, the clutch is not really needed. It is just another option, some will like the feel, others will prefer a direct drive with a pinion. I generally prefer the latter, but I did find a great use for the clutch adapter with a nitro 4tec bell and ran an 1/8 scale on raod car with a 2 speed. Worked like a champ. I did use al clutch shoes from integy, the 3 shoe type that came with a different flywheel. No slip and not bad temps either.
