02.01.2009, 11:03 PM
Well, you may need to rebuild the slipper since you smoked it. Best method is to set the slipper tight, and then back it off incrementally until it slips too much. Then tighten it a bit and you re good to go. 8xl on 6s must be a beast...
Originally Posted by bensf View Post
Ahh. Yea you won't be getting a strobe on there.
I would tighten it down until it stops slipping and then try loosening it and 1/8 of a turn. And keep on repeating that until you get it to where you want.
You only really want it to be slipping on pavement or other high traction surfaces.
Its like we share a brain!
